christoepherr's avatar
Mar 31, 2022
Really at a loss? Self-Assigned IP with Ethernet
I'm really at a loss here and need some help. I'm not sure what happened or what I did. Will try and explain the best I can.
I have CenturyLink Fiber Internet and was given a CX4000 modem/router. The CX4000 was plugged into the patch panel in my closet. In my patch panel I have four white Ethernet cables that correspond to the floor levels in my town home. Each level has one Ethernet port. Those cables are plugged into ports 1-4 of the CX4000. Then there is one blue Ethernet cable that is plugged into the WAN port of the CX4000.
I went into the CX4000 settings to setup Transparent Bridge mode and then removed it from the equation.
I plugged in my RBR850 to the patch panel. The blue Ethernet cable is plugged into the WAN port of the RBR850 and I plugged the other four Ethernet cables into ports 1-4 so each floor can use the Ethernet jacks. I used my PPoE setting to login to get the Internet working for the router settings.
I was able to plug my laptop directly into the wall and everything worked fine. I did a reset and now I get a Self Assigned IP every time I plug my laptop to any jack on the wall. I just did a router reset and don't know why this is happening. Can anyone help? These are my VLAN settings below:
  • michaelkenward's avatar
    michaelkenward
    Is this what you are trying to fix?
    What does this mean?
    The CX4000 has nothing to do with Netgear. Help with that is best sought from whoever made it.
    The RBR850 Orbi router is not one of the Netgear cable modem/routers covered in this area.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi - NETGEAR Communities
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • FURRYe38's avatar
    Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • christoepherr's avatar
      christoepherr
      Tutor
      I don’t have the CenturyLink modem/router being used at all though. It’s in a box packed away. The Orbi Router is the only device plugged into the patch panel in my closet. Everything was working before. I just don’t know how a router reset would cause my Ethernet jacks in the wall to no longer provide Internet and I get a self assigned IP when I try to use them now.
      • FURRYe38's avatar
        You'll need to contact the ISP and have them help you ensure the RBR is connected correctly with there services. Ask if there is a PPPoE account log in needed that may have been set then blown away by a factory reset or any other interface devices that maybe needed to connect the RBR in place of there ISP router.
