Orbi WiFi 7 RBE973
Reply
Setting Up a Wired Satellite
atomx66
Follower
I have a three-pack AX 6000 system.  I live in an older home with dense walls, and one of my satellites has to be placed in an area that results in a significant drop of speed to wireless devices in that part of the house.  I'd like to leave the satellite with a strong signal wireless and make the weak one one wired.  The one I'd like to wire (with a cable connected directly to the router) is already connected wirelessly.
Is it OK to have one satellite wired and another one wireless?  Can I go ahead and plug in the ethernet cable to the satellite, or do I need to do something in settings first?
Thank you.
Message 1 of 3
Accepted Solutions
kildare
Luminary
Re: Setting Up a Wired Satellite
After connecting the ethernet cable everything should go automatically, no settings modifications are required.
Message 2 of 3
All Replies
kildare
Luminary
Message 2 of 3
Chuck_M
Mentor
It is absolutely fine to have a satellite in wired mode -- with or without another in wireless mode.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1306 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
