Orbi WiFi 7 RBE973
Reply
rbk852, Orbi Satellite Model RBS850, spec true?????
KOR-CAT
http://www.downloads.netgear.com/files/GDC/RBK852/RBK852_UM_EN.pdf
Official Netgear RBK852 PDF
140~141p
RBS850 spec
Radio data rates
2.4 GHz: Max 400 Mbps
5 GHz Front haul: Max 866 Mbps
5 GHz Back haul: Max 866 Mbps
What???
Or really?
I'm korean.
Google translate use.
Message 1 of 6
Accepted Solutions
ErnestTheGreat
NETGEAR Employee Retired
Re: rbk852, Orbi Satellite Model RBS850, spec true?????
@KOR-CAT and @FURRYe38 there is a typo in the user manual the satellite specs are same as the router. NETGEAR is working on updating user manual.
Satellite specs on page 141 should also read:
  • 2.4 GHz: Max 1200 Mbps
  • 5 GHz Front haul: Max 2400 Mbps
  • 5 GHz Back haul: Max 2400 Mbps
Message 5 of 6
All Replies
Guru
Are you sure you read that correctly from the PDF file?
Radio data rates: Pg 139
Message 2 of 6
theBrick89
Star
Pg 139 is RBR850, Pg 141 is RBS850. Both are correct on paper.
I wonder if Satellite is really that slow.
Message 3 of 6
Guru
I see. I'll see if I can get some confirmation on this.
Message 4 of 6
ErnestTheGreat
Message 5 of 6
Guru
Thank you @ErnestTheGreat Great to know the actual specs are the same between them. I thought they were.
Smiley Very Happy
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2692 views
  • 6 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
