Orbi WiFi 7 RBE973
Disable Wireless Backhaul (RTGRBH_ Network)
EntropyDF
Follower
I have an RBE771 with with two satellites connected via Ethernet. Everything is working pretty well, no large issues or concerns.
Hardware VersionRBE771
Firmware VersionV10.5.6.5_2.2.22
GUI Language VersionV4.0.0.22_2.1.30.3
Protection Engine Version2.2.214.4/1.0.0.2049
Since I am not using the wireless backhaul, can I disable the wireless backhaul network (RTGRBH___), which is annoyingly visible, is there a way to disable it? Is there a reason not to?
I also note the wireless backhaul network seems to follow my normal wifi network in terms of channel selection, even when I manually move it. I would think it would be better if these were on its own, totally separate channel.
Thanks!
David
Message 1 of 2
Guru
Re: Disable Wireless Backhaul (RTGRBH_ Network)
You can't disable it.
and it changes channels because there isn't a dedicated backhaul like the other versions.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 600 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
