Orbi WiFi 7 RBE973
Reply
ORBI WIFI INTERNAL SPEED TEST
TOPS119
Apprentice
I have notice the orbi wifi speed test shows me a Total different speed result from what its pushing out. I have a 1gb wifi orbi shows im getting 950mb on the app. On the wifi speed test im getting like 500mb what the hell is going on how could we loose so many Mb.
Message 1 of 14
CrimpOn
Guru
Re: ORBI WIFI INTERNAL SPEED TEST
Probably would help to research "What speed should I expect from my WiFi?"
The relevant information is (a) the specific Orbi model capabilities, and (b) the specific WiFi device capabilities.
The original WiFi5 Orbi units are capable of less WiFi speed than the newer WiFi6 products (the AX models).
All Orbi routers have 2x2 MIMO (two antennas).  Theoretical rates for 4x4 systems are not relevant.
In simple terms:
  • A computer connected to one of the router gigabit LAN ports can achieve roughly the same speed that the Orbi router is reporting, just slightly under 1 gigabit. (There is some overhead even in full duplex Ethernet connections.)
  • A WiFi device will get substantially less and this depends entirely on the capability of the WiFi device.
    • A WiFi5 device (802.11ac) will be doing really well to measure 400-500mbps.
    • A WiFi6 device (802.11ax) might reach 600-700mbps when very close to the WiFi access point.
Message 2 of 14
TOPS119
Apprentice
I don't think this is 100% accurate at all. I have the orbi 970 I had 250mb service at start my wifi use to show me the entire 250 plus more, I upgraded to gb service and im seeing 400 to 500mb on wifi. I have seen other person getting almost the full 1gb speed on wifi, im right next to the router and still gets like 400-500 that's crazy.
Message 3 of 14
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Which internal speed test are you running, the RBRs web page? Orbi app?
What wireless device are you using?
What do you see when using a wired PC and Ooklas installable speed test app while connected to the back of the RBR?
Message 4 of 14
TOPS119
Apprentice
I don't think none of this matter based on the fact I just told you we had 250mb before getting speeds of 270-300
upgraded to 1gb and now getting speeds on the orbi speed test of 950mb but on the regular ookla online its 500-600
im using 6a cable I have 3 units house is not too big, system states all satellites are good.
Message 5 of 14
CrimpOn
Guru
It would be very helpful to know the specific model of Orbi and the specific WiFi device that is running the speed test.
Message 6 of 14
Guru
What wireless device are you using to speed test with?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
Message 7 of 14
TOPS119
Apprentice
Re: Orbi 970 Wifi issues with specific devices
I am facing the same issue another problem is, speed. When I plug directly from modem I get correct speed when I use wifi I get half the speed
Message 8 of 14
TOPS119
Apprentice
This is a Caribbean provider
im using the 971.
im getting correct speeds on the orbi net test
im getting correct speed direct wire test
im getting correct speeds on the orbi app test
im testing using a Mac book pro, iPhone, Mac mini
im getting correct speeds hard wired to Mac mini
using Speedtest.net
Once I use the cell phone and test wifi speeds I get half
Once I plug out the cord from Mac mini and use wifi I get half
Mac book pro 14inch latest model half
On the orbi web page all connections are good
I am using 6a cables wired the three mesh
I also disconnected the hard wire used wifi still got half the speed.
Message 9 of 14
Guru
im using the 971.
using Speedtest.net
What is the brand and model of the cell phone?
Which model Mac Mini?
FYI not all wifi devices may get to spec speeds. Depending on there design and support and MIMO capabilities, they may not see anything near 900Mpbs or 1Gb. Most 2x2 devices top out at around anywhere from 500 to 700Mpbs. Depending. Most I ever see on my iPhone 12 pro max is around 700. Mac Book Pro 2018 sees around the same or a bit lower. My android pad gets around 800 range. My Mac Mini 2012 being older generation, only sees around 300-500.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
Wired ethernet speeds should be to spec as you mentioned already.
Message 10 of 14
TOPS119
Apprentice
Im using the latest Mac mini, im also using the latest iPhone 15 pro max they should be able to give the speeds. So at nights I seem o get the correct speeds but in the day the speeds drops this might be a network issue.
Message 11 of 14
Guru
Message 12 of 14
TOPS119
Apprentice
Yep tried it this morning same thing, also had a Orbi tech trouble shoot an entire day trying to see what the issue could be they couldn't fix it either so I don't know im going to reach out to the service provider and see, But based on the fact we getting the correct speed wireless I don't think they will accept that its an issue from them I wouldn't either.
Message 13 of 14
Guru
You'll need to test with the ISP and there hardware, wired and wireless. Test over same time frame.
If you see same issues there with out the Orbi being online, then would be maybe an ISP issue.
Also test with external speed test app like Ookla with a wired and wireless PC.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 1934 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
