- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Once a day or twice a day, the router loses connection to the internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Once a day or twice a day, the router loses connection to the internet and I have to unplug and replug the router. I spoke to tech support and they said this is a known issue and they provided me with new beta software which has not solved the problem.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @FURRYe38 ,
We can mark this issue as solves. In contact with this user on a daily basis and main issue he was encountering is fixed. Issue was due to Pixel 8 Pro crashing his network in V9.10.0.2.
As long as users are in V9.10.2.3 or onwards, Pixel 8 will not crash the system anymore
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Once a day or twice a day, the router loses connection to the internet
I too am looking at my options for return. When it is running it runs like a Ferrari but like a race car it also breaks down a lot and can cause very inopportune problems. It has already crashed once during my wife's conference calls and God help it if it ever does that to me during one of mine. Stable internet is money in my business and this is starting to look like anti-money
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RBR50 with a fiber connection still gave me 250 to 500 downloads, and it never, I mean never went down... I could go on vacation for months and come back and it's singing along . Maybe that's just fine for speed. Seeing 1100 on my cell phone is exciting but not at the cost of stability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the front LED turn PINK when this happens?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Has a factory reset and setup from scratch been performed since last BETA FW update? If not, please try this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello there,
Engineering Team here. Which firmware did Support give you?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using monoprice Cat8 cable.
ATT fiber new install always runs green connection with AT&T modem.
You can't charge thousands of dollars and throw all this troubleshooting on the consumer... Your stock is going to tank.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Trying to help you out is all...If you don't feel it's beneficial, please return the system to place of purchase.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
NBS AT&T BGW-320 500 is the unit
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really sorry for your terrible experience and cannot agree more that you should not go through this. Please assure that we will like to resolve your issue. Please check your inbox for a message, we will like to get this resolved ASAP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option 2 first.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I turn off the wifi then I can't access the modem via the smart home manager app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The IP address that the RBR is getting from the ISP modem? Put this IP address in to the modems DMZ or IP Pass thru feature.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
Might update if you see this, if you haven't already:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @FURRYe38 ,
