× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
Pump Spy
Billy1956
Pump Spy
I Can't get pump spy connected to wifi? It is listed under web URL as allowed but not connected. I turned off Armor and I have the IOT turned off because I have no idea how to set up or connect certain devices to it. The service tech suggested I try connecting the pump spy to the 2.4 network. Any help would be appreciated.
Message 1 of 6
Accepted Solutions
Guru
Re: Pump Spy
Message 2 of 6
All Replies
Guru
Re: Pump Spy
Message 2 of 6
Billy1956
Re: Pump Spy
Thanks, I got it connected. But how do I tell what is connected to what network?
Message 3 of 6
CrimpOn
Guru
Re: Pump Spy
The Orbi Attached Devices screen displays this information in the Connection Type field.
For example, a Samsung tablet was connected to the IoT network of an RBR750:
Notice the Connection Type is 5GHz - IoT
The tablet was then connected to the same router Guest network:
The Connection Type now shows 5GHz - Guest
Another interesting tidbit is that the RBR750 assigns IPs from the primary DHCP pool to both devices on the primary network (wired and WiFi) , but assigns IPs in the 192.168.2.x IP subnet to devices on the Guest network.
Message 4 of 6
Billy1956
Re: Pump Spy
Thank You
Message 5 of 6
Guru
Re: Pump Spy
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1111 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
