- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
(CBK40)with AT&T Fiber
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have AT&T Fiber. Tired of paying for their equipment each month. Purchased the CBK-40. The AT&T ONT only has ethernet. Do I have to connect the CBK via COAX or can I use one of the available ethernet ports or purchase a coax/ethernet adapter.? Cheers ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: (CBK40)with AT&T Fiber
The CBK40 version was the wrong one to buy. its a modem/router combo device and not a router only device. If you're still within your return period, I'd return it or exchange it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The cbr40 isn't compatible with att service. This is directly off the listing:
- Compatible with all major Internet Service Providers — Xfinity from Comcast, Spectrum, Cox, and more. Not compatible with Gigabit service. Not compatible with: Verizon, AT&T, or CenturyLink
- Mark as New
- Bookmark
- Subscribe
- Permalink
As @plemans states, the CBR system only works on cable ISP services. ATT, CenturyLink and Verizon are non cable ISPs, thus DSL FIber or ONT services only.
Contact your ISP to make sure what specific modem or ONT hardware is required before buying a modem system.
I recommend that if you want a orbi wifi system, get ta RBK system instead, i.e. RBK20, 50, 75# or 850 series orbi sytem to use with your ISPs modem. Modem only is recommened for use with these wifi router systems.
Modems having a built in router and wifi connected to a external router like RBK systems, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Good Luck.
@JackRyan2004 wrote:
Thanks. I think it’s the right one. I’m replacing the AT&T equipment with my own modem, router combo. But my question still stands. 😎
