- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CBR40 device and internet issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having multiple issues with my new CBR40. Installed it and set it up with Spectrum as my ISP, per the Netgear instructions. For wireless phones, e.g. iPhone 7plus, the wifi seems to connect just fine but then the internet drops out constantly, like once per minute. For wireless PCs, (Toshiba Laptop, HP), the laptop will see the wifi network and connect to it but comes back with no internet connection. I have both a DirecTV box and a Samsung TV hard wired into the CBR40 and both say no connection... Not sure if all these are somehow related but this is truly maddening. I opened a case with Netgear 6 days ago and still no response...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CBR40 device and internet issues
Please check with the ISP to ensure the signal from there system to the CBK40 is good and working well. Have them check for any log or line issues.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Updated it when I first installed it to what it said was the latest rev. My neighbor has the only other wireless network nearby. The satellites both seem to be working fine. One is about 15ft away but upstairs and one is about 35ft away .
Cable company says there’s been no issues on the line.
Tried configuring per your instructions but unfortunately the PCs and TV still don’t see the internet. They connect to the WiFi just fine. Same issue happened with the phone. Just sporadically saying no internet. The Directv box at least recognized the hard Ethernet line, so that was progress.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset on the CBR40. Then setup from scratch. Turn OFF all RBS and just test with the wifi at the CBR unit.
The one RBS at 15 feet is tooo close. 30 feet distance minimum.
Is Daisy Chain enabled Under Advanced Tab/Advanced Settings/Wireless Settings?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
@rbenso1 wrote:
Thanks for the assistance. Firmware is V2.3.0.10.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thats a shame.
What model Orbi did you get?
@rbenso1 wrote:
Spent 4 hrs on the phone with NETGEAR technical services. Conclusion was there was some kind of hardware problem and to return the gear. Broke out the old Spectrum cable modem and bought a new Orbi router with a couple satellites. It’s working with everything but the laptops. Not sure why....
