Orbi WiFi 7 RBE973
Reply
Is the CRB750 Xfinity Approved
HCC202
Star
Looking at upgrading my CRB40 to a CRB750, but xfinity says that it isn’t an approved device. Is this correct?
Message 1 of 4
Accepted Solutions
Guru
Re: Is the CRB750 Xfinity Approved
I just looked it up on my xfinity account and its showing approved for up to gigabit speeds.
Look for CBR750 under approved devices. You've got it as crb750
Message 2 of 4
All Replies
Guru
Message 2 of 4
HCC202
Star
Thank you I guess it would help to enter the correct model number
Message 3 of 4
Guru
hope it helped 🙂
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 998 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
