Orbi WiFi 7 RBE973
Reply
additional satellite for Orbi CBR40
jcparkey
Tutor
Hi - I bought the Orbi Cable Modem/Router (CBR40) and it came with one satellite.  What are the models of satellites and/or extenders that are compatible with this model?
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 3
Accepted Solutions
jcparkey
Tutor
Re: additional satellite for Orbi CBR40
looks like RBS20 is the best option...shouldhave dug deeper in this group...sorry for the thrash
Message 2 of 3
All Replies
jcparkey
Tutor
Message 2 of 3
Guru
Yes the RBS20 will work fine, also RBW30 and RBS50 will work as well.
Good Luck.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3625 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
