Orbi WiFi 7 RBE973
Reply
2 RBR20 config
Jack2021
Follower
2 RBR20 config
Hello,
 Can I have 2 RBR20 in my home for 2 SSIDs without sync obviously ?
Thanks for your answers
Jack
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: 2 RBR20 config
Yes. Recommend using manual channels that are far apart and placement and distance from the other system will be key as well. Use manual channel 1 and 36 on one system and 11 and 48 on the other.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Also try turning down the power output on one of the RBR wifi radios from 100% to 50% or 25%. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 241 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
