Orbi WiFi 7 RBE973
Reply
5pm1885102063
rrossi59
Initiate
5pm1885102063
I had a power outage. When power restored, my ORBI will not communicate with my modem.  I bypassed the ORBI and internet connection is fine.
I reset the ORBI, changed the enternet cable that runs from the modem, went thhrough a new install process and nothing has worked.
Does anyone have any ideas of what to try next?
Thank you
Message 1 of 3
Guru
Re: 5pm1885102063
Did you power off both modem and RBR then back ON with the modem then let it sync then power ON the RBR?
Does modem have a built in router by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 3
CrimpOn
Guru
Re: 5pm1885102063
I reset the ORBI, changed the enternet cable that runs from the modem, went through a new install process and nothing has worked.
The the Orbii follow the typical "color pattern" of the ring LED during the setup?  i.e. as described in this web page:
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
"reset the Orbi" means (a) turned the power off and back on, (b) used the "reset" hole to put it "back to factory"?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 562 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
