AndyKnight's avatar
AndyKnight
Adjusting signal strength per satellite
Is there a way to adjust the signla strength per satellite from telnet etc?
I would like my rbr40 to be set at one signal strength and my 2 plugin satellites (rbw30's) to be set at a higher strength.  Is this possible?
  • FURRYe38's avatar
    Having this would probably mess with way the mesh system works. You can adjust the power levels on the router I believe.
  • This feature is not available on Orbi, which is a bit disappointing, because adjusting individual AP power levels is standard practice for optimizing roaming performance.  Other managed APs, such as Unifi, have this capability. I supposed it's due to NETGEAR's design goal of keeping things simple to configure, which sometimes involves compromises.
    • FURRYe38's avatar
      I presume since this is a MESH system that some features like that are not compatible which could make the MESH system not work right. NG probably chooses to ensure the MESH system works well and lets the system handle everything. Any changes more than this could effect how it all works. Also roaming is mostly handled by the cllient devices and there algorythms as well.
      • AndyKnight's avatar
        AndyKnight
        The reason I'm asking is because I've had to compromise on where I place the router and satellites so it would be handy to be able to tune the signal strengths of the fronthaul networks on each of the mesh components.
