Orbi WiFi 7 RBE973
Reply
Can I connect a RBK20W to a RBR50 Orbi mesh network
Easypickins
I have a RBR50 Orbi mesh network in my home.  (1 Router, 2 Satellites)  Works Great!
I need to expand the coverage of my Wifi signal.   Can I connect a RBK20W (Router & Satellite) to my existing mesh network to expand my WiFi coverage?
Message 1 of 5
vajim
Master
Re: Can I connect a RBK20W to a RBR50 Orbi mesh network
Message 2 of 5
Easypickins
That does not resolve my problem on how to connect the two systems
Message 3 of 5
Guru
The RBW should work with the ORbi system. Though you may see troubles getting it to connect if the FW on the RBW is out of date or several version behind whats loaded on your system currently.
Message 4 of 5
Guru
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 594 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
