Orbi WiFi 7 RBE973
Reply
Can orbi be used with Netgear routers as access points?
John29466
Follower
Message 1 of 2
Re: Can orbi be used with Netgear routers as access points?
hi
yes the orbi router has the ability to be put in AP mode so you can connect it to your existing router and also still use its sat , this imho would be the best way to use the orbi at this stage
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2551 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
