Orbi WiFi 7 RBE973
Reply
Cannot Get GoGoGate2 To Work With Orbi Mesh (RBK53S)
skancharla
Tutor
Just swapped out an Apple router with the Orbi mesh system.  My GoGoGate2, which controls my garage doors through an app, doesn't work after setting up the Orbi system?!  I see it among my list of connected devices (via 2.4G) but the app can no longer find the GoGoGate2 device.  Seems very strange, this should be pretty straightforward.  Anyone get this to work?
-Sri.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 8
Accepted Solutions
skancharla
Tutor
Re: Cannot Get GoGoGate2 To Work With Orbi Mesh (RBK53S)
Hi, I finally got my working.  Here are all the things I did (not sure which step did the trick?).
1) Logged in the orbi router Advanced -> Setup -> LAN Setup
    Added a reserved address for the GoGoGate2
2) Delete GoGoGate2 device from phone app.
3) Reset GoGoGate2 (button on the face of the device) ...
    When setting up WiFi...
  1. CONFIGURATION MODE: Choose MANUAL.
  2. ENCRYPTION MODE: Choose the type of encryption used by your Wi-Fi network. To check encryption, please check on the link.
  3. AUTOMATIC OR STATIC IP: Choose STATIC IP.
  4. SSID: Set to the name of your Wi-Fi network, where you want to connect Gogogate2.
  5. WI-FI PASSWORD: Input your Wi-Fi network password.
  6. IP: Set to the reserved IP in Step 1
  7. NETMASK: Introduce here the subnet mask (by default 255.255.255.0).
  8. PRIMARY DNS: Introduce here your router’s IP address (192.168.1.1).
  9. SECONDARY DNS: Introduce here again your router’s IP address (192.168.1.1).
  10. GATEWAY: Introduce here again your router’s IP address (192.168.1.1).
4) Finally once you've configured the GoGoGate2, ensure that in device config settings 'Remote Access' is enabled.
These steps worked for me in accessing GoGoGate2 via the Orbi mesh LAN as well as remotely.
G'Luck.
-Sri.
Message 8 of 8
All Replies
CrimpOn
Guru
When you changed routers, did you set the Orbi WiFi network to the exact same name (SSID) and password as the previous (Apple) router?
Message 2 of 8
skancharla
Tutor
Yes the SSID was identical, all my other devices worked without having to reconnect to WiFi.
-Sri.
Message 3 of 8
Guru
What modem are you using? if you're using a combo device, you're apple might have been in ap mode and you didn't change it with the orbi?
https://kb.netgear.com/30186/What-is-Double-NAT
Message 4 of 8
pfOrbi
I have the exact same problem after switching from Velop to Orbi, everything else but Gogogate2 works perfectly.
Dont have double NAT, and i have good reception nearby the Gogogate.
Hopfully hey come with a firmware that fixes this issue...
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 5 of 8
Guru
What exact error are you getting?
Message 6 of 8
CrimpOn
Guru
I suppose you have tried the usual steps of:
  • Pull the power to the GoGoGate2.  Wait 1 min.  Plug it back in again.
  • Open the GoGoGate2 app.  Delete the opener.  Set it up again.
Message 7 of 8
skancharla
Tutor
G'Luck.
-Sri.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1361 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
