trabba's avatar
trabba
Tutor
Jul 25, 2022
Cannot Unblock Occulus Quest
I successfully connected the Occulus Quest 2 to the Orbi RBR50.  It worked well for a couple of weeks.  When I used the "block internet access" function via the app it would not recconnect.  I have gone into the Admin console and tried to unblock internet access and it will not allow it to unblock.  We have tried factory resetting the occulus and forgetting the network to no avail.  There was a reboot of the orbi as well.  It would be great if anybody has any experience with this...there seem to be a few threads related to this function not working well.  Any help appreciated
  • trabba wrote:
    Thanks Crimp on. Yep have followed this steps. Also went into the edit function to try an alternate way. This does not work either.
    Have you tried disabling Access Control completely?
  • CrimpOn's avatar
    CrimpOn
    Sometimes I forget to follow through all the steps:
    • Check the box next to the device that is blocked.
    • Click the "Allow" Button.
    • Click the "Apply" Button.
    I understand that people are drawn to this Access Control feature, but (personally) I find that it seems to cause more problems than it is worth.  If someone can guess my 20 character WiFi password, they are welcome to steal my WiFi, provided that they can get close enough to my house to get a good signal.  I leave it turned off.
    • trabba's avatar
      trabba
      Tutor
      • CrimpOn's avatar
        CrimpOn
