Orbi WiFi 7 RBE973
Reply
Chrome devices not connecting to Orbi wireless after FW update
rohangupte
I have a RBR50 with a satellite. Last week, I downloaded a FW update.
RBR50 is now running on version: V2.3.5.30
SInce then all the Chrome/Android devices have stopped connecting to Orbi. I can go through the detection process, but there is either no internet connection or device cannot connect.
Affected devices:
2 Chromecast Gen2
1 Chrome Book
1 Galaxy A9 phone
I do not have this problem with any other devices - Mutiple IOs devices and Windows PCs.
I have tried multiple resets of the modem, router, phone network setttings, but to no luck.
Any help is greatly appreciated.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 11
Retired_Member
Not applicable
Re: Chrome devices not connecting to Orbi wireless after FW update
Why?
V2.3.5.30 has known problems.
Message 2 of 11
Guru
Is the Orbi system operating in Router or AP mode?
Has a factory reset and setup from scratch been performed since updating FW?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Affected devices:
2 Chromecast Gen2
1 Chrome Book
1 Galaxy A9 phone
Message 3 of 11
rohangupte
I wasn't aware of the problems. What recourse do I have?
Message 4 of 11
Retired_Member
Not applicable
Perhaps backstep the firmware
Message 5 of 11
Guru
Please give feed back to the question presented...lets start there.
Message 6 of 11
rohangupte
My Setup:
Cable ( 150Mbps/10Mbps) > Cable Modem (Arris TM3402) > RBR50 (Router Mode) > RBS50
Performed 2 Factory reset and setup since FW update. Connectivity problems continue with the Chrome/Android devices.
3500 sq ft. RBR50 is on lower level, Satellite is on upper level ~20-30 ft away. Again there were no issues with connectivity or coverage prior to the FW update.
Auto Channels. tried setting manual channels for 2.4GHz - no improvement.
4-5 Neighboring Wi-Fi networks
Beamforming is enabled.
Haven not tried this:
All devices were connecting and functioning perfectly before the FW update.
Message 7 of 11
Guru
You can manually download the last working FW version for the RBR and revert back. Use a wired PC and web browser for this process.
Message 8 of 11
rohangupte
Thank You.
Message 9 of 11
Retired_Member
Not applicable
I'm glad you liked my suggestion.  You're welcome!
Message 10 of 11
Guru
Let us know if this fixes this for you.
@rohangupte wrote:
Thank You.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1632 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
