Orbi WiFi 7 RBE973
Reply
Chromebooks no longer connecting
Stuntman
Follower
Just recently my Chromebooks have stopped connecting to my Orbi wireless. They connect to neighboring hotspots, and to my phone's hotspot... but won't connect to the Orbi.  All other devices in the home connect to the orbi.  I am running the latest released firmware.
Anybody else seeing this?  Any solutions or ideas?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 5
Guru
Re: Chromebooks no longer connecting
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What wifi security mode are you using? Try setting WPA and TPIK, then try WPA2 and AES only.
Was there a update to the Chromebook recently?
I presume other devices connect ok to the Orbi wifi?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 5
Blanca_O
NETGEAR Moderator
Hi Stuntman,
Welcome to NETGEAR Community!
What is the exact message when you try to connect to the Orbi network? Please forget and reconnect to the network on your Chromebooks.
Blanca
Community Team
Message 3 of 5
Blanca_O
NETGEAR Moderator
Hi Stuntman,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team
Message 4 of 5
Guru
@Stuntman Any updates to this?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1681 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
