- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Configure Orbi RBR20 on my Orange Fiber in Spain
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
I'm facing issues to configure the Orbi RBR20 in my fiber network. Basically I have a ONT connected to a router and I want to replace the Orange router with the Orbi. Actually I tried the configuration via app and it's asking the internet credentials if I do select the PPPoE option. Calling the Orange ISP I got the password but they told me there is no user they can give me. I did make several tests with no exit. Is there any thinkg should I try via the ethernet cable //192.168.1.1 configuration?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unsure there is PPPoE in the play...
According to several resources, Orange Spain is plain IP with DHCP on VLAN 832 tagged WAN when it's a direct line. If it is NEBA - this is when Orange doesn't have a direct line to your area - it's VLAN 20 tagged.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Configure Orbi RBR20 on my Orange Fiber in Spain
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @schumakuand thank you for your reply!
Actually I thinkg I don't have plain IP, most likely it's a NEBA as you said. Having said that, should I change the 832 VLAN for a 20 VLAN config? Same priority in this case?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @schumaku , just to let you know I finally did it. Thanks also to your input, it was NOT VLAN 832 priority 0, for NEBA it's 20 0 for all the devices. Olso I was trying to manually configure the DNS, since I moved to automatic it's now working!
Thanks again! Appreciated!
