Orbi WiFi 7 RBE973
Reply
Converting from Circle box to Circle on Orbi
lepack
I’ve been using a Circle Disney box connected to my Orbi router before it became avalaible as part of a recent software upgrade. My question is how do I switch my Circle box over to the Orbi directly? Is it as simple as disconnecting the Circle box and enabling the Circle feature on Orbi? The Circle box has battery backup so I’m concerned about having two instances of Circle running. Will the Circle app automatically recognize the new switch over to the Orbi setup?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 3
troubles
Guide
Re: Converting from Circle box to Circle on Orbi
If the circle box works keep using it. The installed version is subscription based, except for some of the basic features.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 2 of 3
troubles
Guide
I’m gonna dump the Orbi. Makes no sense. What were they thinking. So much for netgear.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1255 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
