Orbi WiFi 7 RBE973
Reply
Coverage of a large area
MarkGZ
Follower
I would like to purchase the proper system to cover my property.  I have a 2100 sq. ft. home and about 500 ft away I have a 2 story 2100 sq. ft. shop.  I have a small garage about 300 ft. from the house.  I have a CAT5 going to the shop now.  Should I get 2 of the Orbi Router and Satallite kits, one for the house and one for the shop?  What would be the best system hardware to keep everything on the same network?
Message 1 of 3
netwrks
Master
Re: Coverage of a large area
You could use the Orbi in your home as Base router and Ethernet connect a router in your workshop back to the Orbi, configured as a Access Point.
Message 2 of 3
so i would assume the internet is at the home ? so all you need there is a router / modem , the shop just needs an access point
the garage you ether need to run ethernet to it and an access point , or use some form of point to point bridge wifi outdoor system
there is a pretty good explanation of point to point below
https://www.youtube.com/watch?v=4zKNIveuCxM
the orbi just isnt right for your needs
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2109 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
