Orbi WiFi 7 RBE973
Reply
DISABLE LAN PORTS ON RBS50
madhatter
Apprentice
I plan on putting the RBS50 (the satellite) in a family room / living room area.  Guests would be able to access the internet through Guest-Mode Wireless.  I want to prevent guests from being able to get onto my LAN by simply plugging in a LAN cable into the RBS50.  Is there a way, in the firmware, to disable the LAN ports on the RBS50 ?  How can I get around this problem without using something like an RBW30?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 20
Accepted Solutions
ekhalil
Master
Re: DISABLE LAN PORTS ON RBS50
@madhatter wrote:
......... I am assuming that this change would need to be re-applied after every RBS50 firmware update, correct?  .......
Commited configuration changes will be stored in NVRAM and will be restored after system restart, power cycle or upgrade. It will also be stored in backup and can be restored.
Message 11 of 20
All Replies
ekhalil
Master
Try the following telnet command in the satellite:
> ifconfig $(config get dgc_netif_lan_phyif) down
Message 2 of 20
Chuck_M
Mentor
Does he have to use the command COMMIT afterwards?
Message 3 of 20
madhatter
Apprentice
I've never used telnet on a router, but am certainly willing to try it ... I just need to know, what, exactly, I need to do.
Thanks
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 4 of 20
Guru
He would also need to enable TELNET as well. TELNET is disabled by default on NG routers. Smiley Wink Use of a telnet program suggestion would be good to for someone who hasn't done this before. Putty or TeraTerm are great telnet programs.
ROUTERIPADDRESS\debug.htm
Message 5 of 20
madhatter
Apprentice
Thank you ... I am assuming that this change would need to be re-applied after every RBS50 firmware update, correct?  Since I will be remote from this router, can I telnet into it remotely if I have remote administration turned on?
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 6 of 20
Guru
Possibly, not sure if changed in telnet persist thru a FW update. Definately not thru a factory reset.
Message 7 of 20
Ragar99
Luminary
Or go the physical route and buy a RJ-45 Port Blocker.
Message 8 of 20
ekhalil
Master
Absolutely, the following commit command is needed:
    • ifconfig commit
Message 9 of 20
ekhalil
Master
@madhatter wrote:
....... I just need to know, what, exactly, I need to do.
  1. From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
  2. Enter admin as user name and your router’s management password
  3. Tick "Enable Telnet" option
  4. Use Telnet from your computer to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
  5. Enter the following commands:
    • config get dgc_netif_lan_phyif    --> printout should be eth1 for RBS50
    • ifconfig eth1 down      --> use the value that you got from the previous command
    • ifconfig commit
Message 10 of 20
ekhalil
Master
Message 11 of 20
madhatter
Apprentice
Thanks to all for your help on this ... very useful info on how to access the LAN port options.  Also helpful was the rj45 port blocker.  The combination will work well for me.
Message 12 of 20
NomadTech
Guide
See this2019-03-12_2-24-31.jpg under settings. And put satelitte in a closet.
Message 13 of 20
madhatter
Apprentice
thanks for the idea, the satellite will need to be located in a more open area, though.
Message 14 of 20
Chuck_M
Mentor
For some reason the post above is truncated
Message 15 of 20
ekhalil
Master
The post is just the first line, the rest is @madhatter 's signature 🙂
Message 16 of 20
Chuck_M
Mentor
I got that, can you read his entire post?  At least one line of it is obscured by his signature
Message 17 of 20
madhatter
Apprentice
yes, this is/was the post:
Message 18 of 20
Chuck_M
Mentor
Hatter, check out the attachment and look at a screen cap of your post and signature.
Message 19 of 20
madhatter
Apprentice
thanks, sig looks to be messed up
Message 20 of 20
Top Contributors
Discussion stats
  • 19 replies
  • 7163 views
  • 11 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
