Orbi WiFi 7 RBE973
Reply
DNS setting doesn't really work
lookout2015
Tutor
Installed the 3-pack Orbi system yesterday, updated to current firmware (1.4.0.34), reset, then configured and put into use. Overall has worked pretty well but I'm hitting one issue that's becoming a show stopper
My upstream provider is a cable company, so I have a cable modem in front of the Orbi. The DNS supplied by my cable company is broken in various ways (very slow, returns incorrect cached answers, doesn't return NXDOMAIN when a domain doesn't exist, etc) so I normally configure whatever router I have behind the cable modem do DHCP to pull IP address but then configure my own DNS servers
When I configure the Orbi to do this (Advanced settings: IPv6: Use These DNS Servers for IPv6; Setup: Internet Setup: Use These DNS servers for IPv4), and then configure the Orbi to do DHCP for my devices behind it, it does not work correctly. What I see is that they use the Orbi as their DNS (expected) but that the Orbi is relaying DNS to my cable company's broken DNS (what the cable modem got from DHCP) and not to the DNS servers I supplied in the settings (NOT expected)
Is this a known issue? Are there any workarounds or something I'm missing about how to configure this?
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: DNS setting doesn't really work
Hello lookout2015
Is there possibly DNS settings in the modem that you are using?
DarrenM
Message 2 of 6
MarkC1024
Luminary
What do you have set under Internet setup?  Is that still set to get automatically from ISP?
Message 3 of 6
lookout2015
Tutor
Nope. Nothing configurable in the modem at all -- it just passes what it gets from the ISP
Message 4 of 6
lookout2015
Tutor
Under Internet
- IP Address is set to Get Dynamically from ISP
- Domain Name Server Address is set to Use these
and then I have a primary and secondary filled out
I'm also using IPv6 so under Advanced, IPv6, IPv6 Domain Name Server I have Use these set and then a primary and secondary filled out
Message 5 of 6
MarkC1024
Luminary
Hard to say as I just use what is assigned - haven't really tested setting my own.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3327 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
