Orbi WiFi 7 RBE973
Reply
Disney Circle and Factory Reset
franktribe
Apprentice
I am sure some of you figured this out. But, it is worth repeating. Backup your Disney Circle settings! It is in the Disney Circle App under manage. If you do a factory reset, and re-enable Disney Circle, it will act like you never set it up. You have to go through the account creation process again., then once you are in, restore your settings. Thank goodness I backed up my profiles. It's kind of obvious to backup your settings but, just in case you forgot, back them up! I really like my Orbi and Disney Circle. Things like backing up them make me continue to like it 🙂
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Disney Circle and Factory Reset
Thanks for sharing this great tip!
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2073 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
