Orbi WiFi 7 RBE973
Reply
Ethernet backhaul in AP mode
Boatguy54
Guide
I have one RBR50 in AP mode, wired to a Cisco RV235 router.
One RBS50 satellite via wireless backhaul.
I just obtained a second RBS50 that can be connected via ethernet.  The support page shows the satellites being connected via a LAN port, which makes sense since normally the RBR50 will be connected to a modem or internet source.
Do I need to connect my RBS50 through a second ethernet connection from the RBR50 to the router, or is the WAN connection on the RBR50 to the router going to find the RBS50 connected to the same router?
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Ethernet backhaul in AP mode
You can connect the RBS50 to either the RBR50s second LAN port or to the lan port of your first satellite.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1123 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
