Orbi WiFi 7 RBE973
Reply
FirmWare Corrupted
CrimpOn
Guru
FirmWare Corrupted
I just bought a new RBK53 for my son and had Amazon deliver it to his house (clear across the United States).  I came on a visit to replace his old Nighthawk with the Orbi, and one of the two satellites the Power LED is flashing red.  According to the web site, this means "the firmware is corrupted."  I tried the paperclip.  Failed.  Am I correct that the only solution is to box up the whole thing and return it to Amazon?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: FirmWare Corrupted
You might try to see if you can get FW loaded via the TFTP method on the RBS:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
IF this fails, send back to Amazon. Smiley Frustrated
Message 2 of 4
All Replies
Guru
Message 2 of 4
CrimpOn
Guru
Bless You, it worked!  Naturally, I had brought my lightest laptop running Linux.  Back to the command line to load and run tftp client.  I gave this less than a 1% chance, and the satellite updated to 2.3.5.30 and connected automatically!
Message 3 of 4
Guru
Awesome. Glad it worked.
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 7263 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
