- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
HiRez music streaming problem
So in the last day or so ive been having intermitent problems streaming HiRez music from my Squeezbox touch. I have been experiancing buffering problems. The folks on the Squeezbox forms insist its a WiFi Issue. I have the routers in AP mode. I have changed the 2.4ghz channel , and it seemed to have work for a hour or so. Mind you this is the only device i am have any trouble with. I am using a Fios router thats about 6 months old. Are there any settings i should check/change before performing hard resets on the Fios/Orbi? I have already unpugged everything and repluuged it on. Unfortunatly i can not hard wire into the router. TIA
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: HiRez music streaming problem
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks. How do I perform a factory reset and setup?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Two ways, by entering the RBRs web page and selecting ERASE under Administration/Backup Settings or by pressing the reset button in back of the RBR/RBS for 15 seconds then release. Walk thru the setup wizard and be sure to write down important information for safe keeping.
