Orbi WiFi 7 RBE973
Reply
How can I redirect the TCP port 25211 for use with LIMA?
smarcher
Follower
I am trying to connect my Lima directly to the Orbi as peer-peer, I am supposed to redirect manually the TCP port 25211 to my Lima IP.  Can not figure this out.
Thanks
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Accepted Solutions
Mikey94025
Hero
Re: How can I redirect the TCP port 25211 for use with LIMA?
You're looking for "port forwarding" instructions so that outside traffic going to port 25211 gets forwarded to the internal IP address of your Lima device.  They have some general instructions here under "How to authorize ports?": https://support.meetlima.com/articles/207051206-How-to-make-your-router-work-best-with-Lima
Port forwarding controls for Orbi are accessible via the Advanced tab: http://orbilogin.com/adv_index.htm, under Advanced Setup.  You can find the internal IP address of your Lima device under the Basic tab, by clicking on Attached Devices and looking at the Connected Devices list.
Message 2 of 2
All Replies
Mikey94025
Hero
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3151 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
