Orbi WiFi 7 RBE973
Reply
How to hide my SSID?
armoredsaint
Apprentice
I know you can hide the Guest SSID, but what about the main wifi SSID? I can't find it
also the guest ssid when you de-select, it hangs also...another glitchy netgear software
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: How to hide my SSID?
Click Advanced-Advanced Setup-Wireless settings there you can un check broadcast the SSID of each band.
DarrenM
Message 2 of 5
moutainraven
I do not see the option to hide main SSID in Advanced Wireless Settings.  Only have option to hide Guest's
Message 3 of 5
st_shaw
Master
Unless you have old firmware or something, it's there.  Read Darren's instructions carefully and look again.
Message 4 of 5
the main question here is why hide ssid in the first place , its not a security setting nor is it good betworking practice
have a read of
http://www.zdnet.com/article/the-six-dumbest-ways-to-secure-a-wireless-lan/
its the second on the list if that gives you a good idea
just securing with wpa2 is a far better option
pete
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5287 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
