Orbi WiFi 7 RBE973
Reply
Motorola MB8600 and Orbi RBR20 not getting along
zippityz
Follower
I read a similar post regarding the MBR8611, but I haven't seen anyone post about the 8600.  Long story short, I've had the RBR20 for a number of years and it's worked fine.  In December I upgraded the modem to the 8600 and ever since then my internet connection has dropped once or twice a day.  All of the lights on the modem are fine, but there's just no WIFI internet.  If I reset the modem everything's fine.
I can't test the LAN connection because if I move the ethernet cable from the Orbi to my computer when the internet isn't working, I need to reset the modem to get it to connect to the desktop, which always solves the problem.
I've had Xfinity techs come out twice.  Both times they found some interference on the line and did something to correct it, but the second tech told me that the Xfinity logs are showing that the modem has been up for 20ish days, when I know that can't be the case.
I never thought it could be the Orbi since it worked fine with my old modem.  But today, when the internet dropped, I tried connecting to the modem's IP address to pull the modem event log and it couldn't connect.  So that tells me that there's a communication issue between the Orbi and the 8600 that goes beyond just the internet connection.
Has anyone figured out which device is to blame here?  I'm outside the return window on the modem, but I did just buy an Arris to give that a go since this entire time I thought the modem was to blame.  And my firmware on the Orbi is updated.  Thanks!
Message 1 of 2
Guru
Re: Motorola MB8600 and Orbi RBR20 not getting along
Does the top ring on the RBR turn on PINK?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Try a wired PC connected to the modem with out the RBR online. Power OFF the modem for 30 seconds then back ON after you connect the PC to the modem.
Be sure the CAT# LAN cable between the modem and RBR is of good quality. CAT6 is recommended.
Try a different modem.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 653 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
