Orbi WiFi 7 RBE973
Reply
Need option to capture DNS querires and force the router DNS (port 53 intercept)
RonV42
Luminary
I have had this feature on other routers where port 53 is captured by the router and then the routers DNS server is used.  I use OpenDNS with varous controls and it's too easy for devices to override and go though custom DNS settings bypassing the OpenDNS controls.    This is a very simple IP table command.  Yes I understand that some network devices/appliances like to use their own DNS configuration (VoIP, IPTV,  etc.) but I have yet to find that forcing the DNS to something else breaks them.
Message 1 of 2
rhester72
Virtuoso
Re: Need option to capture DNS querires and force the router DNS (port 53 intercept)
Orbi won't do this - you need a fully-featured router on the edge and use Orbi in AP mode.
Rodney
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2736 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
