Orbi WiFi 7 RBE973
Reply
Nest X Yale lock disconnects
dalewebb
Orbi RBR40 plus 2 satellites
Have many Nest products including thermostat, Nest Protects, Nest Hello, and a Nest X Yale lock.  The Nest x Yale lock keeps dropping it's connection (maybe other devices are too; I don't know).  The Nest x Yale tech support agent is blaming the router (Orbi with 2 satellites).  Anyone else have trouble with this device?  Any clues how to fix it?  Firmwear is up-to-date.
Dale Webb
Message 1 of 14
Accepted Solutions
dalewebb
Re: Nest X Yale lock disconnects
Thank you for all your help.  I think I have my modem bridged and the PPPoE set up on the router.  Things appear to be working fine.
Thanks again.
Message 13 of 14
All Replies
Guru
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 14
CrimpOn
Guru
"Dropping its connection" can mean different things:
  • The device disappears from the Orbi "Attached Devices" display.
  • The app that controls the device stops functioning.
Is it correct to assume that the lock appeared to install correctly and operated successfully for a period of time?
How does the lock get reconnected?
Thanks
Message 3 of 14
dalewebb
I'll try and answer all your questions:
Model NameDevice NameCurrent VersionStatus
RouterRBR40RBR40V2.3.5.30No new firmware version available.
SatelliteRBW30Orbi Satellite-1V2.3.5.6No new firmware version available.
SatelliteRBW30Orbi Satellite-2V2.3.0.4No new firmware version available.
Zyxel C3000Z
What is the size of your home? Sq Ft?  What is the distance between the router and satellite(s)?
About 1200 sq ft.  Modem and router are in the basement.  Satellite 1 is almost directly above the modem/router in the upstairs.  Satellite 2 is about 20 feet from satellite 1.
2.4 Ghz: 11
5 Ghz: 48
My phone "sees" about 4 wifi networks.  Most are quite weak.
Lock has operated successfully for up to a month, then will go offline (Nest app tells me it is offline.  Guess I don't know exactly what that means.)  Nest tech support tells me the LOCK is offline.  The Nest Connect is working nominally.
Occasionally, it just seems to reconnect without intervention.  Usually, I have to remove the batteries for a time and then put them back in to reconnect.
I'll try the suggested changes in your list.
Thank you.
Dale Webb
Message 4 of 14
CrimpOn
Guru
2.3.5.6 shows as the current firmware for the RBW30.  Might be worth a few minutes to download the firmware from the support site:
https://www.netgear.com/support/product/RBW30.aspx#RBW30%20Firmware%20Version%202.3.5.6
Unzip the file, navigate to the satellite web page, and then do a manual firmware update.
What does the Attached Devices display show the lock connected to? (router, satellite1, satellite2)
Message 5 of 14
Guru
Zyxel C3000Z
This has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
The distance between the RBWs and RBR is too close. This is probably causing too much wifi signal over lap between these devcies. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Message 6 of 14
dalewebb
I called Centurylink to configure my modem (Zyxel C3000Z) to bridging mode and all he had me do was switch the WAN settings from the current PPPoE setting to Transparent Bridging.  My internet went away.  He said now, I needed to contact Netgear to configure the router.  Is there an article somewhere to configure the Orbi router?
Message 7 of 14
Guru
Check the user manual for Orbi
If your using PPPoE, you'll need the account login and PW for your PPPoE account with your ISP.
Message 8 of 14
dalewebb
I have been using PPPoE for a long time and I have the modem's router radios turned off.  The lock has stayed "attached" for the last 24 hours.
Message 9 of 14
Guru
Yes, when the ISP modem is briged, the PPPoE connect needs to be now handled by the RBR. The PPPoE account information needs to be input in the RBRs web page.
Message 10 of 14
dalewebb
Can't find anywhere to input the PPPoE information in the Orbi configuration software.  Can you help?
Message 11 of 14
Guru
Message 12 of 14
dalewebb
Thanks again.
Message 13 of 14
Guru
Enjoy. Smiley Wink
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 10175 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
