Orbi WiFi 7 RBE973
Reply
Netgear Orbi Firmware Update
GreenHornet18
Follower
My Orbi system has been working great for the approximate 6 months I have had it. However recently I have had issues only with the sattelite with the connection to devices frequently failing.
I performed the most recent update 2.3.1.48 and now its even worse.
According to the online GUI at routerlogin.net, the backhaul status is good but when a device eventually connects to the sattelite, nothing loads i.e. videos and websites.
Users on the r/orbi reddit have experienced the same issue with this update.
Please can this issue be fixed ASAP.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Netgear Orbi Firmware Update
Try a full factory reset on the RBR and RBS and set up from scratch. Ensure both RBR and RBS are on v48.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 489 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
