- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Orbi and setting up a Moca network...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used to have Verizon Fios and the Quantum Router. I have gigabit internet, and now I just have internet service (so I know my coax is run and moca compatible).
I currently have the Netgear Orbi ac3000 system, and it's pretty good. I'm looking into setting up a MOCA network though for increased speed/lower latency while still having a robust wifi network. I saw these:
actiontec moca bonded 2.0 adapters
I'm wondering if I can still keep my Orbi system as is, and have one of these adapters plugged into a gigabit ethernet port on the back of the router and the coax into the adapter to provide wired ethernet over coax. I don't want to use the quantum router, but i guess i could if i needed to. Again i only have internet service so i don't care about any tv features or anything.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Orbi and setting up a Moca network...
You might contact the Mfr of this adatper to see if it will work with home class routers...I presume it should work. You could hook up a external network switch that would help...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is what I have setup at my house. Since I'm renting I couldn't run ethernet everywhere but I can use the COAX to hardwire things that can't be wireless. I've had this setup on two generations of Airport Extremes and now Orbi without an issue. I currently have AT&T FIber but I did have this setup when I had Frontier FIOS.
I'm using a pair of ActionTec Moca adapters ECB6200K02 and ChannelMaster 4 port adapter CM-6004. The ActionTec is connected to my Orbi.
If you have any COAX splitters make sure they pass the MoCA frequencies and you should be good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it turns out for you...
