- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Newly bought RBK50 constantly lose internet, after setting up "Block services", "Schedule"
Hi all,
I have bought a RBK50 set few days ago.
I have set time limit access on one of the device in the network (My kid's), by the following steps:
1. Under the advance setting, I assigned a specific IP for the device. (192.168.1.8 for the device MAC address xx:xx:xx:xx:xx:xx), under "LAN Setup"
2. Under "Security", "Block Services", I added this IP address 192.168.1.8, block service type: "Any"
3. Under "Schedule", I set every day, from 22:00 to 21:00
I would expect every day between 22:00 to 21:00, the internet for this specific device would be blocked, and this device could access to internet between 21:00 to 22:00. However, every day all the devices within the network all lost internet connection at 22:00. The internet connection of other devices only resume, after i pressed "Apply" in the page "Block Services" and "Schedule"
Is there any solution? Does anyone have any similar experience?
Many thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Newly bought RBK50 constantly lose internet, after setting up "Block services", "
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Firmwire is V2.6.1.40
Internet Service Provider modem: Huawei EchoLife HG8240H
Just wonder anyone see similar issue, or is it because I set up something wrong...
Attached my setup pages of the router
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
so every night 10pm, all the devices are still connected to the Orbi wifi network, but all lose internet connection.
10pm is the start of the "block services" for that particular 192.168.1.8 device only in advance setting
thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What mode is your modem working in? Router or bridge mode? If router mode, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi,
Thanks. I confirm that the modem is in bridge mode, not router mode.
Just wonder anyone experienced this?
Thanks
Daniel
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I haven't tried new FW yet.
Has a factory reset been performed since last FW update then setup from scratch. Don't setup any blocking services to see if the system works normally. If so, then setup some blocking services and see what happens...
