Orbi WiFi 7 RBE973
Reply
Not connecting to Circle
Reynosa1984
I just replaced a Orbi Router RBK53 with a new one RBK50 because it kept disconnecting from internet about twice a day.
I usually fixed it by reseting the modem so bouth a new one to see if there is teh modem that was bad.
Everything is working fine, except the Dysney Circle
I have enable it and set up the profiles but it does not actually seems to be filtering anything.
I tried to reset on teh app but it keeps telling me that that it is  "Not Connected to Circle"
Need any advice you can provide.
Roberto
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 6
ekhalil
Master
Re: Not connecting to Circle
Where do you see “Not connected to Circle “?
Is Circle enabled under Parental Control in the web GUI or in the app?
Message 2 of 6
Reynosa1984
Yes. Circle is enabvled in the GUI. I also checked the app and  it gives mne a choice to Disable Circle so it is enabled.
The "Cant connect to circle" appears when I press the  "Reset" button  on the APP.
Message 3 of 6
ekhalil
Master
What does the Circle app say? Open the app go to the menu and select Manage. If Circle can or cannot see the Router it will be stated there.
What if you select one of the profiles in Circle and select History. Do you see any events there?
Message 4 of 6
Reynosa1984
Attached is a screen shot of the screen when I go to manage.
On the profiles I have one set to not filters and one for teens.
On the one for no filters the History button is greyed out.
On the other one is not, but when I click on it there is no history
Message 5 of 6
ekhalil
Master
Ok, the snapshot would shaw Circle ID and other router info if Circle was active in Orbi.
Can you please go to Parental Control in the web GUI, disable Circle and then enable again, to see if anything will change.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1781 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
