Orbi WiFi 7 RBE973
Reply
Nvidia Shield has extremely slow speeds with Orbi RBR50
quietcore
Follower
I just set up my Orbi with one satellite to replace an old airport base station. The computer and iphone speeds all over my home are at least twice what I was getting before, however my Nvidia Shield which is connected to the Orbi with an ethernet cable is as slow as dial up. I have done speed tests on the Shield with google (both wired with ethernet and using wifi) and done the same speed tests on my phone and one laptop so far and the Shield is having major problems with speeds in kilobits not megabits, occasional buffering or drop outs occurred with the base station but I can't get anything to load for more than 10 seconds with Orbi. Any advice? Thanks in advance for any assistance.
Shield on ethernet 1.23mb down/219.4KB up
shield on wifi 280.4KB down/12.8KB up
laptop on wifi 224.6mb down/33.5mb up
iphone on wifi 202.6mb down/36.8mb up
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Nvidia Shield has extremely slow speeds with Orbi RBR50
Since its just the shield have you tried anytype of factory reset on the shield?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1523 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
