- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBK20 with Bell 1G Fiber in Canada
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I am using Orbi rbr20 with Bell Fiber 1000mb down and 750mb up in Canada. The modem provided by Bell is Home Hub 3000 (hh3000), it also has router funciton built-in. When I run speedtest (https://www.speedtest.net/) by connecting my PC directly to the modem (hh3000), I got 1000mb down and 750mb up. However, when I connect Orbi rbr20 to the modem and run the speedtest (same LAN cable and same port), I am only getting ~500mb down and 750up. I have tried different ports on the modem, switching the Orbi from Router to AP mode, disable the wifi functions on the hh3000. However, I can only get ~500mb down. Can anyone help me on this?
Ben
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBK20 with Bell 1G Fiber
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2...
I would contact NG support about this as well if you can't get speeds near 900Mbps on the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
@FURRYe38 wrote:What Firmware is currently loaded?
The latest firmware (2.3.5.26) is loaded.
Modem Combo Units:
Couple of options,
There is no setting to config the modem to bridge mode.
I already disable the wifi function on the modem. Already did the DMZ on the modem for my Orbi rbr20.
The wifi functionality has been disable on the modem.
Try option #2...
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you configure the RBR for AP mode and speed test with a wired PC connected to the RBR?
FYI:
- Mark as New
- Bookmark
- Subscribe
- Permalink
AP mode also showes me around 500mb download speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would make contact with NG support to see if the 20 series supports 1Gb WAN to LAN speeds then...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try that. you might consider trying the 50 series Orbi....
