- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI RBK50 issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
ORBI RBK50 issues
Configuration:
Netgear Orbi RBK50 AC3000 WiFi
Satellte + Router
Firmware
V2.5.1.16 |
Backhaul Ethernet (tried also Wireless)
Guest Network
Both 2.4Ghz and 5.0 Ghz networks enabled
Region | Europe |
2.4G Channel | 6(P)+10(S) |
2.4G Mode | Up to 400 Mbps |
5G Channel | 36(P)+40+44+48 |
5G Mode | Up to 866.7 Mbps |
House is approximately 220m2, and building material is reinforced concrete.
Router is on the first floor and satellite on the second floor. Both APs do have overlap across both floors but with very poor signal strenghts so the satellite is needed. I have had the devices in the house since 2017 and the devices have worked well in the past although there were issues sometimes with the wireless backhaul and signal strenghts. Also the speeds for the devices connected to the satellite were significantly lower than via the router. Were particularly having intermittent issues with a Apple tv which is in a corner room and the link speed seems to be changing constantly. I had fast roaming configured earlier and it was also jumping between the router and the satellite. I have been running a ping both to the satellite and the apple tv. And i can clearly see that the connections drop sometimes. I have also reduced the signal strenghts to avoid the worst overals.. Would not like to buy a new satellite without ensuring that the device is actually faulty.. When i bought the set it cost around 700Eur, so would hope to be able to use the devices still.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ORBI RBK50 issues
If I'm reading this correctly, your router on the first floor is connected via network cable to the satellite on the second floor. Do you have any other access points connected or just the 2 Orbi devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@yazi wrote:
No other Wifi APs, the devices are running on AP mode. Orbi devices are connected to a 1 gig switch and have a Fortinet firewall and a 1Gb/s connection.
First thing I would do is rule out the Fortinet firewall and bypass it. See if that fixes it. If it does, something may have changed in the firewbox. Also check cable connections and try different ports on the switch. I had an HP smart switch start to malfunction. I had real slow speeds and disconnects. Switching ports solved it. But I still replaced the switch. These days I use Netgear ProSafe GB switches, unless I need smart capabilities.
- Mark as New
- Bookmark
- Subscribe
- Permalink
