Orbi WiFi 7 RBE973
Reply
ORBI down & Android App won't connect
DNavaro
Initiate
After 7 months of solid performance, my Orbi router just stopped working.  No longer accepting wireless connections.  Tried connecting via my Android S8 and the Orbi app, but it won't connect even though I'm connected to the Orbi wireless network- keeps saying TRY AGAIN.  So I reset the Orbi router to its orginal SSID and pw, but still won't connect after connecting to the Orbi51 default wireless.  Uninstalled and reinstalled the Orbi app, connected to Orbi51 Wireless, tried again (per instructions to TRY AGAIN).  Nothing.  Tried Remote Management, but unfortunately this apparently was never set up.  I don't know of anyway else in.
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 5
Accepted Solutions
Guru
Re: ORBI down & Android App won't connect
Try a wired connected PC and browser?
Message 2 of 5
All Replies
Guru
Message 2 of 5
Leo117
Tutor
CONNECTING YOUR ORBI WIFI ROUTER STEPS
  1. Before Setup powers cycle your network. (Modem, Existing Router if any)
  2. Connect Ethernet cable from modem to the internet port of your Orbi router.
  3. Plug the power into Orbi Router.
  4. Press On/Off button for LED to come up.
  5. Now check if you have internet LED solid.
  6. Connect to the Orbi Wireless network. Find default password under the Orbi router on the label.
  7. Once connected visit orbilogin.net/www.orbilogin.com
  8. Follow the instructions on Orbi genie page.
  9. You can add Satellite also on the same page.
Make sure you reset the orbi router and sattelite again.
STEPS TO RESET YOUR ORBI WIFI SYSTEM
  1. Orbi WiFi router should be plugged into power.
  2. Use paper clip or pin,press and hold the reset button until power LED blinks amber on orbi router.
  3. Do the same on the orbi Satellite.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 3 of 5
DNavaro
Initiate
Honestly, I had not.  Did about 2 minutes of research on the necessary URL and successfully logged in.  Was able to reconfigure the router from scratch and viola!, it's working again.  Also updated the firmware while I was at it.  Thanks for the (what should have been obvious) answer!
Message 4 of 5
Guru
Enjoy. Smiley Wink
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5482 views
  • 3 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
