Orbi WiFi 7 RBE973
Reply
Orbi 50 not allowing connection to streaming services
Stella01
I just installed the Orbi. My problem is that none of my streaming services accessed through a Roku, Nvidia shield or AppleTV will play content. I am able to access the interfaces all apps on these devices but Netflix, HULU, or any other paid service will not play. I get an error message from the provider that “sorry could not access that file”. Is there a setting somewhere that I am missing. Too bad, since the coverage and speeds seem excellent. On the other hand I can play my own content via Plex from my home server fine. Thoughts?
Message 1 of 12
Accepted Solutions
Stella01
Re: Orbi 50 not allowing connection to streaming services
Success!! I am having zero issues now that I have set the Orbi to AP mode. Thanks SO much for your help and patience. I am a little surprised there was not more upfront info concerning how different modems require different setups. However, thanks for everything.
Message 11 of 12
All Replies
Stella01
I failed to mention that I am able to stream from my iPad. However, not from any other streaming device. I have now tried 2 different Orbi RK50’s and do the the setup 3 times. Each time I get great speeds, good coverage but I am locked out of these paid apps for some reason. I even did a fresh install of the Nvidia Shield thinking that the apps were being influenced by the my older WiFi service. I also was unable to to do a simple app upgrade on the iPad with the Orbi installed. Would just get a message”unable to upgrade at this time”. As soon as I took the Orbi offline and went back to my old Nighthawk router everything worked as normal. Again, would like to take advantage of this system but I am encountering so many problems.
Message 2 of 12
Guru
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 3 of 12
Stella01
Wow, lots of things!
the firmware was updated to the latest, sorry don’t know the #. The modem is the stock AT&T modem/router with a fiber connection. I have since uninstalled the Orbi so some of the info is not available. However, your question about AP mode versus Router mode sounds like it might be an issue. My setup was done via netgear mobile app and everything was done in “auto-mode”. My sassumtion it was setup in router mode. This might be a problem since my AT&T modem is also a router, which from digging a little bit, would suggest it should be set up in AP mode. Maybe this is my problem. One of devices that would not connect did give me an error message of “Port 80 cannot find the expected ....” so a problem with port 80, whatever that might suggest. Of course, this is beyond my technical grasp, but I would love to get this working. I will try all your suggestions and report back. Thanks so much.
Message 4 of 12
Guru
Ya, having a router at the modem will cause problems.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 5 of 12
Stella01
Thanks. I can certainly easily do #2 & 3, since the WiFi is disabled on my AT&T modem. What is the advantage of #1? Obviously, talking with AT&T about anything is a hassle and a crapshoot.
I would need to have the Orbi router be able to also connect via wire, Also the satellite. Is this available in scenario 2 & 3? Sorry for being so unsophisticated regarding these things, but this stuff is SO beyond my understanding. Thanks for your patience
Message 6 of 12
Guru
From my reading AT&T is horrible about letting their devices be placed in modem only mode. So option 1 probably isn't much of an option.
I've never used option 2 that @FURRYe38 listed.
I have used option #3 with orbi and it worked great. Only downfall is losing some of Orbi's advanced functions such as Circle/Armor/advanced lan settings/etc.
You do need the main Orbi connected back to your ATT box via a ethernet wire. The satellite can be hooked up via the wireless backhaul or a wired backhaul. Either will work for both scenarios.
Message 7 of 12
Guru
Advantage of Option #1 is to limit traffic over a router thats built into a modem. If you can get the modem into modem only mode then this will just help pass thru the traffic from the ISP to the Orbi router with out any additional processing. However as mentioned, ATT and some modems are not supporing of fullying being bridged so Try Option #2 so you can keep use of the main features of the Orbi router in router mode, or try #3.
Don't worry about the technical side of things here. Why we are here to help out. Smiley Wink
Message 8 of 12
Stella01
Thanks so much for all the help! I will give scenario 3 a shot today and report back.
Message 9 of 12
Guru
Smiley Wink
Message 10 of 12
Stella01
Message 11 of 12
Guru
Glad you got it working now. Please mark your post as solved so others will know. Enjoy. Smiley Wink
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 9839 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
