Orbi WiFi 7 RBE973
Reply
Orbi AC3000
br30328
Follower
Orbi AC3000
How can i expand my AC3000 RBK53 Triband wifi system for a 7000 sq foot (single story) ranch style home plus garage? The box says you can add a 3rd satellite but where can it be purchased and what are the setup instructions? Cant find any info online and cant get through to netgear (2 calls disconnected both times, 2 hours wasted already, frustrating). Any help would be greatly appreciated.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Orbi AC3000
Hello br30328
Here is the amazon link to a extra unit and all you need to do is the same sync process you did with your other satellite units.
https://www.amazon.com/NETGEAR-Orbi-Home-WiFi-System/dp/B01LZG4KPC/ref=sr_1_1?ie=UTF8&qid=1501866709...
DarrenM
Message 2 of 3
cue003
Apprentice
Re: Orbi AC3000
Looks like a few places online have it. Do a search for a Orbi RBR50. Best Buy, newegg, Amazon, eBay etc all show as having it.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2905 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
