- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi AP setup with Fios
- Mark as New
- Bookmark
- Subscribe
- Permalink
Looking to purchase an Orbi system, my current Luma does not provide the coverage I had hopped in my home.
Reading throught the Fios set up article (https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios) I believe this is the route I want to take. My question is this, do I have to have the primary Orbi connected directly to my Filos Quantum gateway? Would it still work if the Orbi devices were connected to the router via a switch? The switch in question is a "dumb" switch with no VLAN or management support. Reason for this is; my whole home is wired if this config is supported it would mean I only need the two Orbi system. less $$$. Thanks for the input.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi AP setup with Fios
yep connecting to a switch is fine as long as the Fios is running in router mode and the orbi ststem is running in AP mode
just connect the orbi router to the switch making sure its in ap mode , the orbi sat/s do not connect by ethernet however and only connect back to the orbi router via their 5 gig wifi backhaul
