Orbi WiFi 7 RBE973
Reply
Orbi App Speed Test vs Actual
Nansterz
Guide
Last week, we noticed a significant drop in home network speeds. I did the standard troubleshooting, rebooted the modem, reboot the Orbi and we completely lost the internet - I couldn't get a dynamic IP from my ISP. 2 hours and an Orbi factory reset later I got everything back up. As a note, I was previously using default settings on the Orbi and Circle. I didn't make any configuration changes after the factory reset.
Speeds have not returned to their normal speeds, however, the Orbi app is reporting what I expect to be getting.
Orbi app speed test reports 178.14Mbps download, 12.04Mbps upload and 13.0ms ping.
The SpeedTest app on my iPad reports 31.0Mbps download, 10.6Mbps upload and 19ms ping.
I have the SpeedTest history on my iPad and I used to get 180Mbps download, 11.5Mbps upload and 20ms ping. I also confirmed that my iPad is using 5GHz and not 2.4GHz. I also unmanaged my iPad in Circle with similar results.
I also connected my laptop with a gigabit adapter directly to the Orbi and I got 65.08Mbps download, 9.84Mbps upload and 18ms ping. Better than what I'm getting on the iPad, but still half of what I expect to get.
Any ideas, tips? Any advice would be greatly appreciated!
Model: CM700|High Speed Cable Modem—DOCSIS 3.0, RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 12
Accepted Solutions
Guru
Re: Orbi App Speed Test vs Actual
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Is this the CM modem you listed in you product list? You using the RBR20?
You may want to update FW if you haven't already:
https://community.netgear.com/t5/Orbi/RBR20-RBS20-2-5-1-16-firmware-observations/td-p/1897766/jump-t...
Message 6 of 12
All Replies
Retired_Member
Not applicable
orbi model & firmware?
Message 2 of 12
Nansterz
Guide
RBR20 running V2.3.5.30
Message 3 of 12
Retired_Member
Not applicable
not familat with the RBR20
what changed recently to your system?  firmware updates?
many users report problems with app for speed results and other things
Message 4 of 12
Nansterz
Guide
It also comes up as AC2200. I did a firmware upgrade after the factory reset.
Message 5 of 12
Guru
Message 6 of 12
Nansterz
Guide
FURRYe38.. I went ahead and performed a manual update and the speed issue appears to be resolved. I DID run into a snag during the firmware update process - I kept getting "Firmware upgrade failed. Please check your file." on the satellite (that I forgot to mention in the original post). So me being the smarty pants that I am (sarcasm), I tried a factory reset and removal of the satellite from my network. I figured that it would treat it as a brand new satellite upon adding back to the system and would auto-update the firmware. Welp, that didn't work. It recognizes it when I plug it back in and so it's stuck on 2.3.5.6. I tried to update it manually and still getting the upgrade failed error.
I did a speed test and the numbers are back to where I expect them.. I just really need to see if there's a speed difference on devices connected to the satellite and also find a way to get it to take a firmware update.
Message 7 of 12
Guru
Try this on the RBS with v16 RBS FW at the ready:
What you need to do is factory reset the RBS. Wire connect a PC to the 1st satellite. Already have the most current FW version files downloaded on to this PC.
When the satellites are reset, wait about 5 minute. The PC will get a IP address from the satellite. the IP address will be 192.168.1.250. You can look at the network status connection properties to see what the GATEWAY IP address is to verify. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Do this for both satellites. Then factory reset and then re-sync the satellites to the RBR.
Message 8 of 12
Nansterz
Guide
By some crazy miracle, the firmware updated. I’m not sure how or why, but it did and everything has been stable.
Thank you all for your help.
Message 9 of 12
Retired_Member
Not applicable
So what version are you on now?
Message 10 of 12
Guru
Please mark your thread as solved so others will know.
Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. Smiley Wink
Message 11 of 12
Nansterz
Guide
2.5.0.2
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 4052 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
