- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi App in Access Point Mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to use the Orbi app when the router is just in access point mode and using a non-netgear router? I would just like to be access the Wi-Fi settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi App in Access Point Mode
Yes and the app only supports Orbi systems. For non orbi NG routers, you have to use Genie for those models.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply.
Just to be clear and I wouldn't be using any type of netgear router (a draytek in fact) just an Orbi router in access point mode with two other satellites.
I just want to use the Orbi app to access the Wi-Fi settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should work fine for AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
@ciacci wrote:
Same question there is a chance to use orbi app in AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I set up my Orbi router and satellite in access point mode will all the functions of the orbi app ( particularly remote access) still work or will that be disabled while in access point mode? Any input greatly appreciated as I can't find any informaton on this. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
App should work however some features may not be supported in AP mode since they are dependent upon router mode.
You can test this out and see how it works for you, if it doesn't you can revert back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi my point is diffirent i've already set-up in AP mode, all works with web based control interface (using IP nr. for connect not orbilogin.com address) from computer with basic feature not related to a router mode, question is if there is a chance to login with the mobile app (seem no...)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Exactly , the app even if we are under same Wifi is unable to find the router, appear the usual message "issue connecting with..."
consider that also the computer have issue to connect under "orbilogin.com" it works only with exact IP address of the router
I think there is a limit in AP mode that conflict with the app and usual standard addresses
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would contact NG support and ask about this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have used both router and Ap mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
IP addresses of devices like routers, access points ect.
When setting Orbi in Ap mode did you assign a ip or leave it dynamic ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi sorry but i was forced to switch to router mode due to a fault on the other router... now the mobile app works fine
in any case previous set up was: AP mode - dynamic IP or fixed nothing change - only acces wia web based app with direct IP connection, no chance to use the mobile app
Now switching to router mode the app connect flawlessly
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it's working. Wonder why it works for others in AP mode and others no so much.
Enjoy,
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My configuration is a little random 😂
Have my ISP provided router going via Ethernet to Orbi set up in Ap mode.
From Orbi it goes to a 8 port managed switch in another room.
The Orbi Satellite in also in another room using wireless back haul.
Main router has ip of 1.253
Orbi manually set in Orbi to 1.252
Switch manually to to 1.254
Both switch and Orbi have DHCP off
I have other Netgear Nighthawk’s that I tested the Nighthawk app on and connected to switch in Ap mode they also worked as long as I was connected to the right ap was able to use both apps with no problems.
