- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Blocking Overwatch Live Chatting on PS4
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have tried opening up all neccesary TCP and UDP ports for PSN, Blizzard services, and Overwatch. Have also tried putting PS4 in DMZ doesn't work. Disabled all firewall and security settings still nothing. I found another discussion thread that had similar issues that were never solved in January. Thinking about returning router if this cannot be fixed.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this the only game that this happens with?
Can you chat with othres on the PS live chat network while not in a game?
Try changing NAT filter from Secure to OPEN. Save settings then reboot.
Might try a reset on the router, walk thru the set up wizard while the PS is turn OFF. Just set up the wifi and check the speed test if on the router. Ensure uPnP is enabled. Make sure IPv6 is disabled. Do one more reboot then after the router is ready, turn ON the PS console.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Blocking Overwatch Live Chatting on PS4
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
The only thing needed is uPnP. No Port Forwarding rules nor DMZ is needed....
- Mark as New
- Bookmark
- Subscribe
- Permalink
FW: V2.1.4.16
Modem: Motorola Surfboard 6183
UPnP is enabled and still no luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I just Disabled IPv6 and it is fixed now.
THANK YOU for your help!
I'll leave a message in the other thread if i can.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it's working now. Enjoy.
