Orbi WiFi 7 RBE973
Reply
Orbi Lag spikes
jbeem19
Follower
Orbi Lag spikes
I just bought the Orbi with a single satellite a month ago. It worked perfectly until like a week ago and now when I play it's unplayable. 50 ping to 300 ping every 5 seconds or so. Very frustrating, please help. Thanks
Model: RBW30|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 3
ekhalil
Master
Re: Orbi Lag spikes
Please open a Command Prompt on any computer attached to Orbi and type:
tracert 8.8.8.8 (or traceroute 8.8.8.8 if you're using a Mac computer)
  1. If you see two private IP addresses listed in the first two hops then you have double NAT, and this can be the reason for the issue you’re reporting
  2. If you see only one private address and the second hop shows a public address, then you’re all good and we need then to troubleshoot further to find the cause of the issue,
Message 2 of 3
Guru
Re: Orbi Lag spikes
What is the Mfr and model# of the ISP modem the NG router is connected too? If so,
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3639 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
