Orbi WiFi 7 RBE973
Reply
Orbi RBK50 Data Transfer Speed Problem
Santhora
Hello, I have one Orbi router (RBR50) and one Orbi satellite (RBS50) installation in my house. I've been having data transfer speed problem since the day I bought the product. All devices connected by 5Ghz shows speed of 866mbps. but file copy speeds are in the 20 - 30 mb/s. I was using google wifi before and I was getting at least 80-90 mb/s speeds with it. All devices are close together and stably connected. Please help for this problem:(
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 7
Guru
Re: Orbi RBK50 Data Transfer Speed Problem
What are file xfer speeds with a wired connection?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Message 2 of 7
Unlikely. That is way faster than many, perhaps even most, wifi clients can handle.
Which makes me wonder about how you are measuring things.
Message 3 of 7
Santhora
- Wired connection works fine with full speed (110mb/s). Also i tried to connect my devices to Orbi satellite by wired and it works fine too. - My house is 1100 sq ft. But it doesn't matter. Because all devices were tested on the same table with the router. - All devices connected with 5GHz at maximum speed (866Mbps) - I also tried all 5ghz channels (36 to 48) - I tried the Beamforming, MIMO and WMM together or separately on or off. Note: I would like to say once again that i have never had such a problem with google wifi before. Is there any other suggestions I haven't tried?
Message 4 of 7
Santhora
Have you tried looking at the attached picture? There you can see the maximum speed of connected devices under "Link Rate" text. Which means that I can data transfer at about 80 - 100 mbps. Like Google wifi that i used before
Message 5 of 7
Guru
The Link rate is just that, a connection link rate between the RBR and the connected device. This differs from actual data thruput or data flow between the RBR and any connected device. Two differences here and are not the same.
https://networkengineering.stackexchange.com/questions/39235/bandwidth-vs-throughput-vs-databit-rate
Message 6 of 7
Santhora
I know that there are different terms. I am not ignorant. Everything I want to say is stable and at maximum values. Please tell me how i got so low data transfer rates. please focus on providing solutions, not telling me terms
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1319 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
